1gb - from 500mbps speed unchanged
wullieg
Upgraded from 500mbps to 1gb still getting the same speeds not clued up on this at all
6 REPLIES 6
carl_pearce
Super solver
Wired, wireless, both?
What does this site show?
https://samknows.com/realspeed/
Just getting the exact same speed as before as I said new to all this not clued up at all
What does the above site show?
Access your Hub on 192.168.0.1, select 'Check router status' under the login box, then check the 'Configuration' tab.
Should look like this:
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
87dsfd;kfoA,.iyewrkldJKDH
SFID
889
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
1420
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
John_GS
Hi wullieg
Thanks for posting and welcome to the community. Sorry to hear of the lower than expected speeds. How are you testing wired/wireless and on what devices? All looks good following a system check.
Best,
John_GS
Samknows 1145 into my house 497 to my device
Try this site:
https://proof.ovh.net/
I find some speed test sites are not very consistent, unlike the above one.
Also, I don't think you confirmed if you've tested on a wired device?
