sound but no picture
just got a new samsung tv
connected everything up like normal got sound and tv guide but cant see a picture tried different hdmi leads even tho i knew the ones i have work but still no difference turned box on and off turned tv on and off but still nothing has anyone else got an idea doing my head in now
  • 10.89K
  • 871
  • 2.39K
Re: sound but no picture
This means that the TV isn't giving a correct handshake to the box, try restarting the box, then the TV, (if that doesn't work, if no joy post the model of the TV and we'll see if anyone else has had the same issues
  • 12
I have a Samsung and it is becoming more frequent. It is becoming a nightmare turning the TV on and off at the mains !!! My Samsung Model Number is UE55RU7020KXXU. We only bought the TV 2 months ago ! Everything is up to date with the TV Software and also the V6 box. Nothing wrong with my HDMI Cables. Swapped ports with other devices - - still happens. Help Please.
  • 1.74K
  • 81
  • 135
Hi preludebabe,
Thanks for your post, sorry that you are having issues with your sound, are you able to connect the V6 to a different tv to see if it is the box or if it is the tv itself?
Zoie
  • 12
Unfortunately no. But we have a dvd player connected and a gaming console and they are absolutely fine. These connections are the ones we swapped around.
  • 1.74K
  • 81
  • 135
Thanks for getting back to us,
I have sent some hits to your box remotely please let us know if this helps.
Zoie
