johnjoliver1952
Message 1 of 5
remote control pairing
 I need the exact code to pair the remote to tv, its an 55HK25T74U J
can anyone help please, I have tried all available codes
  • 5.76K
  • 916
  • 1.36K
Hero
Message 2 of 5
Re: remote control pairing
Hi johnjoliver1952,
Have you tried the codes in this PDF? TV Remote Code List
Also a  lot of customers have found the following method works for them:-
Go to HOME > Help and Settings > Help > Set up Remote.
Follow instructions there it should give you a series of codes to try.
You can also put 0999 in place of the code and press channel up until the TV turns off, then press ok.
Dave
johnjoliver1952
Message 3 of 5
yes  I have tried all the codes
Alex_RM
  • 4.3K
  • 247
  • 327
Message 4 of 5
Hi johnjoliver1952,
Sadly there are some TV's that aren't compatible, if you've tried all the codes then there would be nothing further we can do.
This may be something that's added at a later date.
Alex_Rm
johnjoliver1952
Message 5 of 5
THANK YOU
