NewToTivo
iPlayer etc doesn’t load
We got VM this week and setup The TiVo box
- Connected to router via Ethernet and the box is 1m from the router
Added Series links to some shows and none of them will load episodes e.g. a BBC programme that says open in iPlayer.
click to open the program and get spinning wheel for a few seconds and then it just goes back to the previous page
Tags (1)
japitts
  • 14.41K
  • 1.92K
  • 3.29K
Re: iPlayer etc doesn’t load
I'm assuming you have a V6 and not a TiVo...check here if you're not sure.
I'm unclear whether you're reporting...
1: A problem with your series links not scheduling recordings? If you can post details - your SL settings, and examples of "missed" programmes, we can advise
2: Problems with loading the iPlayer streaming app? Can you watch non-BBC OnDemand programmes (this will test your box's internet connection)? Can you load the iPlayer app manually via Home > CatchUp > Channels > BBC?
