jayhcee
  • 13
connect Tivo to hub3
What benefit is there to connecting my Tivo to Hub3 via ethernet and powerline, and is a 5 metre cable too long?
Ernie_C
  • 18.41K
  • 2.02K
  • 4.51K
Re: connect Tivo to hub3
For the old TiVo, the only benefit comes if you have more than one TV box, allowing Multi-Room Streaming.
Anonymous
Not applicable
network cables are good to 100m
