  • 14
Will my virgin media coaxial cable socket work with a free view box?
I have an old virgin media wall socket to connect to a coaxial cable that I used to use for my Samsung ntl box. I thought freeview set top boxes didn’t need an Ariel connection but it seems they do. If I use the Ariel box I used for the ntl box, would it work? I don’t know if it connects to a rooftop Ariel or not. I only remember having a dish for sky on the roof as it’s my mums house but I don’t remember whether there was a rooftop Ariel as well if virgin media even use them. If this isn’t an option, would an indoor Ariel connect to the freeview box as it’s one where I can pause and play and record tv so I’d like to use that rather than just using a indoor Ariel directly into the TV.
  • 12.44K
  • 859
  • 3.72K
Re: Will my virgin media coaxial cable socket work with a free view box?
The NTL socket wont work
An internal ariel connected to the freeview box will, depending on signal strength in the area
  • 14.84K
  • 2.05K
  • 6.44K
You would be better off installing an aerial rather than trying to use a brand of washing powder.😉
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
