LesWDorset
  • 10
Volume control on television
My system set with an engineer requires that the Sony TV remote is required at opening and closing TV viewing.
The Virgin remote has been working alright in terms of the volume control until a week ago.From that point we have been unable to adjust the volume with the Virgin remote.I have used the virgin fault system to try and correct,but to no avail.This includes trying a number of Sony Bravia four digit codes.I have been unable to access a direct conversation,hence the message.
Tags (1)
  • 5.65K
  • 910
  • 1.33K
Hero
Re: Volume control on television
Hi LesWDorset,
The following method has worked for a lot of customers
Go to HOME > Help and Settings > Help > Set up Remote.
Follow instructions there it should give you a series of codes to try.
You can also put 0999 in place of the code and press channel up until the TV turns off, then press ok.
Also you could try the following Sony codes from the online remote codes  TV Remote Code List
0018 0045 0101 0131 0154 0177 0211 0301 0302 0357 0358 0609 0785
Dave
LesWDorset
  • 10
Dave,
Appreciate your reply and response to my question.
