Benji35
Volume and TV power not working
The other day my virgin tv box went off completely then all of  sudden cam back on within an hour.
Since this the volume and the TV power on the remote are not working.
Can anyone help get them working again.
japitts
  • 8.72K
  • 1.23K
  • 1.69K
Re: Volume and TV power not working
Which box do you have? If you're not sure, check here
There's instructions on re-pairing your remote on all VM boxes here
