thenippy
  • 7
Virgin tv remote code
I bought a new hitachi 65 inch tv 9 months ago but virgin still can’t provide a code (TV model number 65HL26T64U) for their remote to work volume control and I was just wondering if anyone had got theirs to work. I also have a 4K fire stick and it was able to pick up the volume straight away?? It’s so annoying using 3 remotes to do everything. Thanks in advance 👍
  • 5.66K
  • 910
  • 1.33K
Hero
Re: Virgin tv remote code
Hi thenippy,
A member of the Forum Team posted this  a month or two ago which has worked for a good number of people.
Hi, if you go to HOME > Help and Settings > Help > Set up Remote.  Follow instructions there it should give you a series of codes to try.  You can also put 0999 in place of the code and press channel up until the TV turns off, then press ok.
Apart from the ones programmed into the remote there are also the following codes from VM TiVo TV Remote Code List
HITACHI
0014 0018 0020 0022 0033 0044 0049 0050 0074 0086 0099
0101 0102 0104 0107 0110 0119 0126 0127 0150 0152 0161
0162 0165 0166 0168 0171 0178 0182 0186 0203 0213 0218
0219 0231 0233 0238 0309 0379 0456 0475 0611 0613 0622
0631 0633 0636 0671 0795
You could also try contacting Hitachi as they may not have supplied VM with the relevant code
Dave
  • 5.66K
  • 910
  • 1.33K
Hero
Hitachi TV's are now manufactured by Vestel and Finlux for the UK market, so it's possible a remote code for those makers will work.
You can try selecting them on your remote inbuilt list - and also those below from the PDF link in the previous post
VESTEL 0044 0049 0101 0107 0125 0152 0166 0379 0654
FINLUX 0020 0025 0042 0045 0049 0078 0080 0090 0091 0101 0102
0104 0107 0110 0145 0152 0163 0166 0197 0203 0206 0210
0219 0222 0231 0324 0375 0379 0407 0408 0428 0429 0433
0437 0449 0460 0465 0622 0631 0643 0685
Dave
thenippy
  • 7
Thanks again for your help with the codes but none worked will just have to keep trying. 👍
