Hi there,
My V6 box has been stuck on a loop for the past few days - when turned on, it displays the welcome screen for a few minutes, then switches to the "starting up" page and then back to the welcome screen. Occassionally the screen displays a sort of download icon, but then this gives way to the welcome screen and the loop continues.
I have tried rebooting several times, (turned off rocker switch, hold down + & standby, hold until "welcome screen")checked all cables are secured in place and left the box on for hours hoping it will sort itself - all to no avail. I tried running a fault finding test online but that didn't work either, as it just say all is fine. Have had difficulty getting through on the phone to speak to someone.
Does anybody know how to fix this please or if they are experiencing the same issues?
Thank you,
Sam
