ImpactChosen
Message 1 of 5
Upgraded to sky cinema not working
I was called on thursday with a deal to upgrade to sky movies ,but they havent been activated yet have reset box several time to no avail ,any help on here as been hung up on twice after waiting an hour on hold both times 😞 not happy!
Tags (3)
  • 6.56K
  • 1.02K
  • 1.63K
Message 2 of 5
Re: Upgraded to sky cinema not working
Hi ImpactChosen,
Using your remote control you could try and force a channel update. Press HOME Help & Settings > Help > Virgin T> go up to the top of the screen then TV Care and press OK >  Missing Channels.? > Refresh my channels list
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
ImpactChosen
Message 3 of 5
I will try that aand update here if it works thanks for that info
ImpactChosen
Message 4 of 5
That has worked thank you for your help
  • 6.56K
  • 1.02K
  • 1.63K
Message 5 of 5
That's brilliant.
Thanks for the update ImpactChosen.
Stay safe and take care.
Dave
