letsaveit
Message 1 of 7
Up volume does & down does up
We got a y tv and done all the codes then tried the 0999 and keep pressing up channel button, it turned tv off and pressed ok, it now does volume but the up volume turns it down and down does up, mute does not work, can turn tv off and on. Any idea how to resolve the volume so it goes up when pressing up.
Tags (1)
Ernie_C
  • 18.38K
  • 2.01K
  • 4.49K
Message 2 of 7
Re: Up volume does & down does up
You have the wrong code and will need to persevere to get the right one.
letsaveit
Message 3 of 7
Iv done all the codes the tivo box suggested so tried the other way it says by doing clear and tv at same time then press 0999 then keep pressing up channel till tv turns off, iv tried this many times but the volume is in reverse
David_Bn
  • 4.89K
  • 225
  • 401
Message 4 of 7
Good Morning letsaveit
Sorry to see you'v been having issues with the volume function on our remote control with you TV set.
Can you please advise me if this is still on going?
If you are still struggling, can you please advise me of what make and model your TV is?
Kindest regards,
David_Bn
letsaveit
Message 5 of 7
Sharp Aquos
David_Bn
  • 4.89K
  • 225
  • 401
Message 6 of 7
Hi letsaveit
Can you try the following codes for me;
0123, 1223, 0187, 0066, 0521, 0683, 0286, 0546, 0790, 0848
See if any of those will work for you
Kindest regards,
David_Bn
  • 5.65K
  • 910
  • 1.33K
Hero
Message 7 of 7
Hi letsaveit,
There are also the following codes which may work
SHARP 0007, 0018, 0044, 0094, 0154, 0170, 0190, 0308, 0320, 0362, 0631 and 0675
TV Remote Code List
Dave
