1iking
  • 5
Message 1 of 5
TiVo problem
Hi all
I desperately need help ! My TiVo box keeps recording episodes of Peppa Pig. I have no series link for the program. I have tried creating one , then cancelling it but it's still recording episodes. They are all from nickjr. I even created a series link and set number of recordings to 1, it still records them all. Please help
Alan
japitts
  • 10.44K
  • 1.46K
  • 2.1K
Message 2 of 5
Re: TiVo problem
At a guess, this could be a wish list or suggestions. I'm nowhere near my box to check currently, but from memory, suggestions can be checked under Home > Help & Settings > Settings > Recordings.
I think wishlist should show under Series Links from memory.
1iking
  • 5
Message 3 of 5
Re: TiVo problem
Thanks for the reply japitts. I have not created any wish lists and suggestions are turned off !
LittleMick73
  • 4.93K
  • 513
  • 839
Superstar
Message 4 of 5
Re: TiVo problem
Hi then after turning the function off perhaps rebooting the box may cure it.Regards Micky
1iking
  • 5
Message 5 of 5
Re: TiVo problem
Thanks for that Mick. Powering down seemed to do the trick. I am now Peppa Pig free
