chrisclc01
TiVo box won’t turn on
My TiVo box initially had a green screen stating an error had been detected and would take 3 hours to fix. Has since rebooted itself, downloaded an update and now doesn’t get past the start up screen before it constantly restarts.
any suggestions?
chris
japitts
  • 11.97K
  • 1.66K
  • 2.56K
Re: TiVo box won’t turn on
I'm afraid your TV box has failed and you will need a replacement.
Call TV Faults to report & arrange it - 150 from a VM phone, 0345 4541111 otherwise.
