PMCG77
TiVo box making noise
Hi there,
My Virgin TV box has started making a humming/whirring noise in the last week. It is pretty noisy - you can hear it over the TV when it is on.
It also makes the noise when the box is asleep and the red light is on.
The box is approx 2.5 years old. Otherwise appears to be functioning normally.
Amy ideas?
thanks
japitts
  • 12.07K
  • 1.68K
  • 2.59K
Re: TiVo box making noise
Could be the sound of the hard drive spinning? Or an early indicator of hard drive failure. Hard to be sure without knowing how loud it is.
