Remck
TV signal dropping in and out repeatedly
Hi for a while now our tv signal drops in and out for several minutes when first turned on. It only stops after I have turned the tv and sometimes the virgin box on and off again. Has anyone else experienced this? Or have a solution?
thanks
japitts
  • 12.31K
  • 1.7K
  • 2.65K
Re: TV signal dropping in and out repeatedly
Are you saying that the TV picture is dropping out, but you can still view the TiVo menus etc? That's a fault.
Or that your TV is losing connection to the HDMI lead from your box? That could be an iffy HDMI connection - try different sockets/cables?
