KevinLimb
TV displays serious DVR fault and doesn't reset after 3 hours
Screen is green with white text.
  • 7.86K
  • 1.16K
  • 2.14K
Re: TV displays serious DVR fault and doesn't reset after 3 hours
Hi KevinLimb,
Sorry to see you are having major problems with your Tivo box.
You need to contact the Faults team on 150 from a Virgin landline, or 0345 454 1111, options 1,1 and 2 (Faultsbut best to call at 8am to avoid call queues or around tea time.
When calling Faults you will get the automated response asking you to press 1 for the link to online support, ignore the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and resolve the problem.
You could also try the text messaging service. Just send  a text with a description of TV Faults to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
KevinLimb
Really helpful answer...thank you!
I have a replacement Tivo box within 2 days. Calling at 08:10 to the Faults team with only 15 mins wait.
KevinLimb
  • 7.86K
  • 1.16K
  • 2.14K
Hi again KevinLimb,
Thanks for the update. That's brilliant news.
Hope it's all working ok for you now.
Stay safe and take care.
Dave
