zeewier
  • 55
Message 1 of 5
TV cable needs to be shortened
As subject. We moved our TV V6 box and now we have quite a bit of unsightly excess coax cable. I understand it is not advisable or allowed to cut the cable myself, so I would appreciate a visit of a VM technician.
Andrew-G
  • 7K
  • 1.22K
  • 3.06K
Message 2 of 5
Re: TV cable needs to be shortened
VM will charge £99 for a "non-fault" visit.
Can't you carefully coil it, secure the coil with two cable ties, and make sure the coiled bit is tucked in a discrete place?  If you do this, don't kink the cable, that'll be a disaster because it destroys the signal, so even doing it carefully you'll probably have a coil with a diameter of at least eight inches.
zeewier
  • 55
Message 3 of 5
Thanks for your reply, but unfortunately coiling is not an option, there is nothing to hide the coil behind. I know about the £99 charge...😠 I am hoping to book a technician via this route rather than calling VM.
Andrew-G
  • 7K
  • 1.22K
  • 3.06K
Message 4 of 5
In which case there's a bit of a wait (perhaps 3-5 days) for the forum staff to respond, but they will eventually, and that should avoid the need to phone VM's "eighth circle of Hell" call centre.
Tom_F
  • 3.42K
  • 205
  • 438
Message 5 of 5
Hi zeewier, thanks for getting in touch - apologies for the delayed response.
In case this is something you still need help getting sorted I'll contact you via PM to confirm the details we'll need.
Tom
