bigpete35
  • 6
Message 1 of 5
TV Guide/info button on remote showing "to be announced" on various channels. Limited program info
When we press Home/TV Guide buttons on our remote to browse for & plan upcoming programs to either watch or record the listings on a lot of the channels are showing "TO BE ANNOUNCED"  this is also happening on a lot of movie channels & is very annoying because it makes it impossible to plan what to watch if you don't know what's on.
  • 4.83K
  • 787
  • 1.11K
Superstar
Message 2 of 5
Re: TV Guide/info button on remote showing "to be announced" on various channels. Limited progr
Hi bigpete35,
have you tried forcing a reconnection to the network?
Using your TV box remote:
  1. Select the home button
  2. Use the directional buttons to select Help & Settings
  3. Select Settings
  4. Select Network
  5. Select Connection in progress: get status or Connect to the Virgin Media Service now
Dave
  • 20.72K
  • 2.2K
  • 3.67K
Message 3 of 5
V6 or Tivo?
bigpete35
  • 6
Message 4 of 5
Sorry for the late reply John.....  Tivo
bigpete35
  • 6
Message 5 of 5
Thanks for that Dave.......................................  just carried out your advice & it seems to have worked.
