Lornaxliza
Message 1 of 5
TV Guide Says to be announced
Have reset boxes, tried connect to virgin media services and on getting info says 'connection interrupted'  any ideas please?
Craig_w4128
  • 126
  • 34
  • 34
Message 2 of 5
Re: TV Guide Says to be announced
Can you confirm what type of tv stb you are using i.e V6 or tivo 500?
If you PM me ill run thriugh a few checks for you
Craig
Why not try our Text Messaging Service?
It’s a great way to get help with your Virgin Media services - and it's free!
Just send your query to 07533 051 809 and we’ll text you back.
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
I am a serving Field Technician at Virgin however all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
norman4uk
  • 5
Message 3 of 5
my  guide and menu   say "  to  be  announced  "       for last  few  days        have i  touched  something  by  mistake  on my  remote   for this  to  happen
norman4uk
  • 5
Message 4 of 5
tivo  box
  • 5.67K
  • 911
  • 1.33K
Hero
Message 5 of 5
Hi norman4uk,
It sounds like the box has lost it's network connection.
Using your TV box remote:
  1. Select the home button
  2. Use the directional buttons to select Help & Settings
  3. Select Settings
  4. Select Network
  5. Select Connection in progress: get status or Connect to the Virgin Media Service now
Dave
