Sound & Picture drop out v6 box
Hi, I'm getting sound and picture drop outs on my VM v6 box.
It happened months ago, then seemed to stop...but now its back with a vengence.
If I remove and replace the HDMI cable that can sometimes stop it for a while...but then it comes back.
It can be as often as every 10-15 seconds, or be minutes in between. Its very annoying
v6 box directly connected to Samsung f8000 via HDMI.
Sound drop outs and mixture of white flash (like a camera flash) or full blackout of picture (accompanied by the TV showing the connected input e.g. HDMI1 1080 50hz)
Please help
  • 1.44K
  • 100
  • 132
Re: Sound & Picture drop out v6 box
Sorry to hear that you're having problems with your TV pst99.
If this issue is happening over multiple HDMI cables, this definitely sounds like there could be an issue with your box and I would need to get this looked into further.
Please could you respond to the private message that I will be sending over in a few moments and I can look into this for you.
Steven_L
