Phil2202
Sky cinema signal
Since upgrading our package to include the  Sky Cinema channels we have consistently had issues with pixelation on the screen to the point these channels are unwatchable. Even if we record a film the recording is faulty. I have followed all the instructions for the equipment but nothing has worked. Phone lines are very difficult to get through. Any suggestions?
many thanks
SCA1972
  • 5.79K
  • 654
  • 1.94K
Re: Sky cinema signal
If you can't get through on the phone then VM are recommending you send a text to 07533 051809 describing the issue and you should get a response, but it may take a day or two at present. This is a text only service, it does not support voice calls.
https://community.virginmedia.com/t5/Digital-life/When-and-how-to-use-our-messaging-service/ba-p/425...
You can wait here for a response from the forum team but it may also take a few days.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
