eversm
  • 11
Sky cinema doesn't fill screen on v360
Just switched to v360
All Sky Cinema shows in letterbox format with thick upper and lower border.
Any ideas why is doesn't fill the screen?
paul0363
  • 538
  • 64
  • 180
Rising star
Re: Sky cinema doesn't fill screen on v360
It's displaying correctly - the black bars are because cinema aspect ratios are wider than your tv screen and the film is letterboxed to its correct aspect ratio.
You'll need to go into your TV settings and select "zoom" or equivalent from the aspect ratio settings if you want to remove the bands (but you'll also lose the edges of the picture).  The black bands are broadcast by Sky so there is no other way to remove them.
