jrobertson1989
  • 6
Message 1 of 9
Sky channels not working
Seem to be having continuous problems with the Sky channels that I'm subscribed to (Sky Comedy, Sky One, Sky Witness) where I just get a black screen with an Error Code W02. I've checked all the fittings and everything seems to be screwed in correctly with no noticeable signs of damage to any of the cables. Anyone have any experience of this? I have a Tivo box by the way.
japitts
  • 10.33K
  • 1.44K
  • 2.07K
Message 2 of 9
Re: Sky channels not working
Is this specific to the channels you've mentioned, and are they the SD or HD variants?
Only because it might help further isolate the problem - the chances are that you have a signal fault which only VM intervention can ultimately fix.
jrobertson1989
  • 6
Message 3 of 9
Yes, from what I can see the rest of the channels seem to be working perfectly well so only the sky channels I'm having issues with. These are SD channels, not HD.
Gareth_L
  • 6.1K
  • 374
  • 657
Message 4 of 9
Hello jrobertson1989
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Gareth_L
  • 6.1K
  • 374
  • 657
Message 5 of 9
Thanks for passing security jrobertson1989
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
jrobertson1989
  • 6
Message 6 of 9
Thats great, thank you. I just tried to reschedule for the following week as I'll be at work on that date but it currently says the app is unable to show the reschedule calendar. Would you be able to re arrange the appointment for any day the following week??
Many thanks
Gareth_L
  • 6.1K
  • 374
  • 657
Message 7 of 9
Thats been rebooked for you now jrobertson1989
Gareth_L
jrobertson1989
  • 6
Message 8 of 9
Thats great, thanks very much
Gareth_L
  • 6.1K
  • 374
  • 657
Message 9 of 9
No problem at all jrobertson1989
Please keep us updated on how the visit goes
Gareth_L
