lindav7
Sky Cinema issues
We have the sky cinema channel. There is no dialogue only the movie sound affects. No voices coming through. Is anybody else having this problem? There is no issues on any of my other channels.
nodrogd
  • 16.45K
  • 1.92K
  • 3.93K
Re: Sky Cinema issues
Do you have a normal TV or a sound system attached?
If its a normal TV go into the sound settings on your V6 box.
Home>Help & Settings>Settings>Audio>Dolby Digital, & change the setting to "Dolby Digital to PCM"
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
lindav7
Thank you, this has now resolved the problem 🙂
