Replacement remote?
How can I get a replacement remote for virgin tv?
  • 599
  • 64
  • 88
Rising star
Re: Replacement remote?
Contact Faults on 150 or 0345 454 1111 & go through the routing for a problem with TV; they'll be able to assist & either try get it working on the call or to send a replacement. In the meantime you can use the Virgin Control App which can work as a remote whilst you wait for a physical one.
** I work for VirginMedia but all opinions posted here are my own.
