Remote is faulty- no help from Virgin
my Tivo remote began playing up over a month ago, you have to press the buttons tens of times before you get a light on it and a response from the box. I've changed the batteries but it makes no difference.
I contacted Virgin via a help email address twice but got no response at all. I then contacted their helpline and sat through their testing process only to be fobbed off with ' there's a problem with the service in your area which we're aware of', as if this would have anything to do with my faulty remote!
I'm really cheesed off with this, my partner has health problems and she's having to get up to change channels on the Tivo box itself which is a massive fiddly faff. Can someone please send me a new remote or I'm leaving- don't think that I haven't noticed that I can get a much cheaper deal elsewhere and I won't miss Virgin's price rises every few months either!
  • 31.39K
  • 1.64K
  • 5.49K
Re: Remote is faulty- no help from Virgin
if you can get a cheaper deal then why are you staying. That doesn't make any sense. you should move to the cheapest provider
  • 936
  • 72
  • 176
Well-informed
Have you tried calling and reporting Tv fault call 150 from VM landline choose Tv faults.
  • 4.8K
  • 294
  • 547
Hello Jonf21
Sadly we are not able to order remote controls on our Forums pages
You would need to give us a call
This way we can also look at the cost each month as well as ordering a new remote for you.
In the meantime you can download a remote on most devices here
Gareth_L
