Rammstein1972
  • 18
Remote control keeps skipping
Hi,my remote keeps skipping menu channels by two at a time.We changed batteries to brand new ones and still keeps happening.Thanks.
Tags (1)
  • 6.46K
  • 1.01K
  • 1.6K
Re: Remote control keeps skipping
Hi Rammstein1972,
You should be able to order a replacement remote using this direct link virgin-tv-lost-or-damaged-tv-remote
If it doesn't work then you will need to speak to TV Faults to request a replacement. Dial 150 from a VM landline
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
