Reduce package & slow speed
Ive been trying for a few weeks for someone at Virgin to contact me, phone twice and left a message by text as requested on FB.
mid like to reduce my package and also speak about my Broadband as it drops out and doesn’t seem to be the speed I signed up for.
I’ve also found that our mobile phones work better on the 4G than on the WiFi.
thanks,
  • 30.31K
  • 1.51K
  • 5.26K
Re: Reduce package & slow speed
VM won't call you back you will need to contact them
Call in or txt
Due to the current situation there is a text message only service is available via: 07533051809 Just send a text with the issue you are facing and someone will get back to you as soon as they can.
