Caitlinmillar
Recordings keep freezing
I’ve only had my box for a couple of months and any time I watch a recording on it it freezes. I’ve restarted the box so many times and still doesn’t make a difference. I’ve only got a few things recorded at 2% usage. Is there anyway to solve this? Find it difficult to get an answer from the virgin media text phone number as they always reply when I am working and then the query starts over again when I reply.
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Re: Recordings keep freezing
Does this affect all your recordings, or just particular ones?
How about when you pause/rewind live TV?
Caitlinmillar
It’s all recordings. I hadn’t noticed it when rewinding live tv before now, but last night after I paused something for about 30 mins I played it and it was still freezing.
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Sounds like your box has a hard drive fault, which can't be repaired.
It's only likely to get progressively worse until it fails outright.
