Daveyb83
  • 6
Re: sky sports golf picture quality
I have a similar problem on all my HD channels.
I'm based in Central London and this problem is not solved.
Daveyb83
  • 6
Re: Picture pixelation
I've got this problem with all my HD channels.
I have done:
- reset the box
- changed HDMI cable
- Tested other services work sufficiently (and they all do so it is not the TV problem)
- text Virgin media - no response
- called 150 and was told to call again in 24 hours time
- rung after the allotted 24 hours and didn't get a response after being on hold for 2 hours.
No idea what is left to do
japitts
  • 12K
  • 1.67K
  • 2.57K
Check by calling 0800 5610061 that there's no reported issues in your area. If there's not, then there's a fault that VM don't know about - which could be your box, your cabling or somewhere else - but you will likely need an engineer visit or replacement box.
TV Faults on 150/0345 4541111 should be your next port of call. You may get lucky with calling through tonight, not sure when they close on Sundays.
Daveyb83
  • 6
I tried calling back yesterday twice but after waiting over an hour the call disconnects automatically. i'm on hold right now and I have been for over 20 minutes.
pc4
  • 8
good luck
Daveyb83
  • 6
I'm already on a 40 minute hold waiting for a response
