Can you clarify what your issue is?
Looks like you added to a thread from 2020 discussing a problem with the EPG updating (long since solved), but have described a problem reading the screen - which could be the high-contrast display being on/off.
A different issue entirely - can you perhaps take a picture of your screen demonstrating your issue?
