motoJ
Re: aRe: Problem with tivo box picture
I have a problem with pixelation / blocking on HD channels.
My box is a Samsung SMT-C7100.
Number of tuners is 3: tuner 0, tuner 1, tuner 2
Home | Help & Settings | System Info | Diagnostics
AGC (automatic gain control) signal level: 79%
Tuner 0 | Signal strength: 59%
Tuner 1 | Signal strength: 0%
Tuner 2 | Signal strength: 0%
Swapped Tivo box with V6 box: V6 diagnostics reports 100% signal strength on all 6 tuners and no evidence of pixelation on HD channels so there cannot be a signal issue on the cable to the box. And the Tivo box reported the same (poor) signal strengths at the original V6 location.
Compared a HD channel recorded on both boxes at the same time: Tivo=pixelation, V6=ok which tells me there is not a problem with the signal outside the house.
With the tuner strengths above, a HD channel on tuner 0 pixelates less frequently compared with a HD channel on tuner 1 which pixelates every few seconds.
So I am certain there is an issue with the tuners in the Tivo box. Call centres are closed - I'll try another time.
Tuner 0 sometimes reports a 'tuning error' on the diagnostics page.
I have restarted the Tivo box and have been monitoring the picture and diagnostic reports for several days to build up a picture and conclude that the Tivo box is bad.
japitts
  • 11.99K
  • 1.66K
  • 2.56K
Swapping the boxes alone, is enough to prove the box is faulty - so I recommend you call Virgin to report it.
150 from a Virgin landline, or 0345 4541111 from any other phone, and follow the options for "I have a fault with my TV service". The faults agent should be a be able to do some remote diagnostics and either arrange (hopefully) a replacement box or (possibly) an engineer visit.
