Bill_Paisley
Re: DVR serious issue
I am also affected by this issue. Have contacted technical support digitally without any reply and am unable to spend hours on hold to call. Can someone organise a new set top box to be sent out please?
japitts
  • 11.97K
  • 1.66K
  • 2.56K
As with all faults issues on this board, you just need to be aware that responses from VM staff can take anywhere from a few days to a week.
I don't recommend giving up on calling through to C/S in the meantime. If you try perhaps earlier in the day you may get through quicker.
