Almik
  • 32
Problems with vbox
  • My sons vbox has a home screen saying it’s now a TiVo . No channels are working. Asking to restart TiVo, when it’s a vbox? Confused.
  • Error code C130
jb66
  • 12.17K
  • 900
  • 1.76K
Re: Problems with vbox
It's not a vbox, it's either a tivo or a tivo v6
  • 5.76K
  • 916
  • 1.36K
Hero
Hi Almik,
From the Help pages tv-error-codes/c130
You will need to reboot your TV box, to do this simply turn it off and on again
 If that doesn't work page 2 advises
Step 2 - Connect to your Virgin Media Service
Using your TV box remote:
  1. Select the home button
  2. Use the directional buttons to select Help & Settings
  3. Select Settings
  4. Select Network
  5. Select Connection in progress: get status or Connect to the Virgin Media Service no
And if that fails you need to contact TV Faults.
You could try the text messaging service. Just send  a text with a description of TV Faults  to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
You can also call  150 from your Virgin landline, or 0345 454 1111, options 1,1 and 2 (faultsbut best to call at 8am to avoid call queues
Dave
