Dr_Rod
Just joined
Poor sound quality BT sport
Sound quality on all BT sports channel on at least 8 occasions poor and twice out of sync with pictures. Only affect BT sports channels.
What do I need to do ?
Al
roger50
  • 30
Re: Poor sound quality BT sport
I noticed this on by sport ultimate tonight it was dreadful especially through the sound bar I had to switch it off the sound bar.
  • 5.64K
  • 908
  • 1.32K
Hero
There has been a recurring problem with sound on BT Sport Ultimate and the recordings, however not on the normal BT Sport HD Channels.
Over the past couple of weeks with the European football BT commentators have been apologising for the sound quality and also the fact it's often out of sync.
A solution that often works is  to switch from Dolby Digital to  to Dolby Digital to PCM in the Audio settings.
Other people have found changing HDMI cables solves the problem.
Dave
