CJamesRo
Message 1 of 7
Pause doesn’t work
Received a new virgin tv remote, managed to set it all up, volume works.
However the pause button doesn’t work at all, on live tv or recordings. If you press the pause button a thin bar comes up at the bottom of the screen with the length of the programme and just says ‘quick view is off’ ect. Frustrating that you have to stop your recording or are unable to pause live tv at all...
Martin_N
  • 5.3K
  • 224
  • 302
Message 2 of 7
Re: Pause doesn’t work
Hi CJamesRo,
Thank you for your post. I'm sorry to hear this.
That should only show up when you press the play button.
^Martin
CJamesRo
Message 3 of 7
Well on our remote, (long flat one, replacement from virgin) the play/pause button is the same button. But like I said if you press it it doesn’t pause at all
LittleMick73
  • 4.94K
  • 513
  • 840
Superstar
Message 4 of 7
Hi that doesn't sound like a virgin remote they are all rounded even the latest V6 ones. Regards Micky
SimonRo19
Message 5 of 7
This is a Virgin remote. I requested a new remote as the original one developed a very annoying time lag. The new one is indeed long and thin, and the pause button certainly does not work; nor does it allow you to pair the remote to the box.
Zoie_P
  • 2.52K
  • 119
  • 198
Message 6 of 7
Hi SimonRo10
Thanks for your post and apologies to hear you are having an issue with getting your remote control working.
As simple as it sounds, have you tried repairing the remote with the V6 box? If not follow these steps to do this:
1. Go to Home > Help & Settings > Settings > Devices > Remote Control Pairing.
2. Press and hold the Info button for 7 seconds until the light at the top of the remote goes solid green then flashes green twice.
Zoie
  • 5.72K
  • 914
  • 1.35K
Hero
Message 7 of 7
Going by the description of the remote, the OP is in Ireland.
Help for Virgin Remote in IE  https://www.virginmedia.ie/customer-support/support-by-products/tv/
Dave
