Amber60
Message 1 of 7
No sound
I have had no sound for a week now using my Virgin and at breaking point due to unhelpful staff. You can’t speak to anyone..frustrating!! I have tried everything to fix this including rebooting my box at least twice a day, changing ports, checking wires, using paper clip to reset box and still no sound. I will be cancelling my DD if I don’t get any help here
Tags (1)
japitts
  • 11.98K
  • 1.66K
  • 2.56K
Message 2 of 7
Re: No sound
Does restarting your box resolve the issue? Even if only for a short time.
However frustrating the service may be, I would not recommend cancelling your D/D. VM don't take kindly to missed payments, and it will make whatever C/S problems you have, worse. Potentially also impacting on your credit file.
Amber60
Message 3 of 7
Re: No sound
No...it makes no difference whatsoever that’s why I am so frustrated as this has been like this for over a week now.
I sent a complaint to Virgin today regarding their customer service
  • 6.44K
  • 1.01K
  • 1.59K
Message 4 of 7
Re: No sound
Hi Amber60,
Does following the advice here help? your-tv-sound-isnt-working
If you have a sound bar then try it without the sound bar as that or the sound bar cable may be the issue.
I had the same problem as your good self and solved it by having a spring clean behind my TV (it was like spaghetti junction) I unplugged everything from the mains  including each device (TV, TV, computer, router, Nintendo Switch etc). Then after straightening everything out I reconnected everything up and voila, the sound was working again.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Amber60
Message 5 of 7
Re: Port config test failure
Mine is exactly the same, says it has failed. Not been getting any sound for 9 days now on TV or apps..great picture though so wondered if that was the problem 🙄
Amber60
Message 6 of 7
Re: No sound
THIS PROBLEM HAS NOW BEEN FIXED BY AN ENGINEER 👍
japitts
  • 11.98K
  • 1.66K
  • 2.56K
Message 7 of 7
Re: No sound
Thanks for posting back with an update.. for the benefit of others who might be reading this thread, was this a remote fix over the phone or a home visit?
Do you know what they did?
