Just joined
My remote for tivo box is faulty
My remote ci trol for tivo box is playing up when using remote to put sound up or down it goes up by 4 or 5 at a timr
  • 14.5K
  • 2K
  • 6.35K
Re: My remote for tivo box is faulty
Have you tried changing the batteries?
If it still remains faulty after so doing then call it in to the faults line.
The numbers to ring are 150 free from a VM mobile or landline, or 0345 454 1111 from any other phone (chargeable as standard UK landline phone no.).
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
