Grayson17
Moving box and cables
Im looking to build a false chimney breast with tv in the wall and a gazco fire installed too. I do not want my virgin media tivo box and entry box/cables on show.
My plan is to move the TiVo box behind the TV and the virgin entry points to be boxed in.
Is this possible? I’m also concerned that the remote won’t work on the tv if the box isn’t on show?
Anonymous
Not applicable
Re: Moving box and cables
the v6 remote can work using RF.
If you need the cable box moving VM has to do this and they will change £99.
They will not box it in so you'll have to do that once its moved
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Hello
Only a VM engineer can move cables and that will be a chargeable call out as  non fault of £99.
Depends which box you have if you have standard Tivo then that is Infra Red only, If you have a v6 then remote is RF for the box and IR for the TV.
Tivo
V6 Box
Regards Mike
