fineogs
Message 1 of 5
Missing Channels Sky 1 & Sky 1 HD since V6 box locked up
Hi - hoping someone can help - fed up waiting on 150 and just keep getting txt msg - but it never arrives
My Tivo V6 locked up last night - did a power reset and when it came back chans 101 & 109 & 110 are missing BBC 1 ,  Sky 1 & Sky 1 HD.
My package is Full House so they should be there but the are missing  - list goes from 108 to 111
I reloaded the channels via Help Settings Network - connect to Virgin media server - this got BBC1 back but not Sky 1.
Any ideas?
Cheers Paul
  • 4.72K
  • 768
  • 1.08K
Superstar
Message 2 of 5
Re: Missing Channels Sky 1 & Sky 1 HD since V6 box locked up
Hi Paul,
Welcome to the community forums.
Sorry to see you are having issues with missing channels. I see you have reconnected to the network.
I'm hoping this may help.
Please can you try the following. Using your remote control go to
 Help & Settings > Help > Virgin T> go up to the top of the screen then TV Care and press OK >  Missing Channels.? > Refresh my channels list
This may take around 20 minutes and you may need to reboot
Dave
fineogs
Message 3 of 5
Hi - tried that , still the same  , I'm still waiting on 2nd line support from Virgin to get back to me.
Thanks for the help though.
fineogs
Message 4 of 5
Just as an update - I can see Sky1 on demand - but still not showing on V6 Box - but tivo box has the missing chans 109 & 110. oh well Virgin Engineer coming out tomorrow.
fineogs
Message 5 of 5
Solution was to replace V6 Box - lot of recordings on it though and no way to copy them over 😞
