Sam9170
Losing sound when changing channel
I’m losing volume when I change channel sometimes. It comes back after vigorous channel hoping or turning the box off 3-4 times.
  • 6.51K
  • 1.02K
  • 1.61K
Re: Losing sound when changing channel
Hi Sam9170,
Using the remote to Home > Help & Settings > Settings > Audio > Dolby Digital > Then select Dolby Digital to PCM to see if that resolves the problem.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
