  • 30
Incorrect Channel Guide
New episodes of Countdown broadcast 14/11/19 - 19/11/19 incorrectly appeared in guide as first shown 05/11/18 - 08/11/18 with no New Tag, so recordings are missing (have series link ).
  • 3.32K
  • 330
  • 624
Re: Incorrect Channel Guide
Not being a Countdown viewer, but C4 certainly have form in putting repeat or re-edit shows in the middle of new series.
In any case, the guide can't be corrected for the past, only the future - so you're best using 30day CatchUp for these episodes.
For future guide errors, you can email them to tivoguideerrors@virginmedia.co.uk - you won't usually get a reply, but genuine errors are usually resolved in a day or two.
