Alexlouise7
Message 1 of 5
How do I replace sky tv with Virgin tv. I have 3 sky boxes over 3 floors....
Hi Everyone, I have virgin high speed internet 350 and want to now come away from sky tv but need to have sky sports and keep the package similar. Problem is I don't just have 1 tv, it's a big shared house and we have 3 tv's over 3 floors. There seems to be now way to account for this on the order for the extra bundle and no way of communicating this or getting a quote for it?
The extra 2 sky boxes are wifi connected not wired in. Virgin are also not taking calls at the moment so can't call them....
Many thanks
Alexlouise
LittleMick73
  • 4.93K
  • 513
  • 839
Superstar
Message 2 of 5
Re: How do I replace sky tv with Virgin tv. I have 3 sky boxes over 3 floors....
Hi the short easy answer is wait until this situation is over. Regards Micky
cranforduk
  • 94
  • 11
  • 14
Up to speed
Message 3 of 5
Additional Virgin media V6 boxes need to be connected via coax but in addition need connecting to wifi. This can be wireless if you can get a signal otherwise via ethernet cable or even using powerlines. Since you are over 3 floors running the coax cables could be tricky.
You will need an engineer to set this up so as above you will need to wait.
nodrogd
  • 16.46K
  • 1.92K
  • 3.94K
Message 4 of 5
VM installers only carry short ladders & are not heights trained. As mentioned earlier, live channels & most On Demand content is delivered direct via the coaxial cable to the TV boxes, not over a network connection. Unless this connection can be achieved by internal wiring on the upper floors you will not be able to use Virgin TV.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Roger_Gooner
  • 6.53K
  • 473
  • 1.14K
Legend
Message 5 of 5
VM will not install multiple TV boxes until the current crisis passes.
The boxes on the floors above the hub can be connected to the coaxial and Ethernet cables by drilling holes in the ceilings and lifting floorboards, and then having pull ropes for the VM tech to install the cabling.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
