Shaznie
Help .. box stuck on clearing data
Can someone please help?
Last night I wanted to delete all recordings on my box, went to settings, all confirmed then I got a message saying “sit tight this could take a few minutes” well 20 hours later it’s still there!
i tried turning off tv and box by rocker switch on the back - nothing. I also held down tv+record button to reboot on box.. nothing.. help lol
  • 930
  • 72
  • 174
praxis
Well-informed
Re: Help .. box stuck on clearing data
When you switch the box off did you remove plug as well ? If not try that leave for 5 minutes then put it back on if you are still having the same problem time for a phone call call 150 from VM landline and choose Tv faults.
  • 10.18K
  • 757
  • 2.15K
You can try this, it will wipe your box (if it works) switch off the tivo wait 30 seconds and switch it back on and hold TV+Down+Record buttons on the front of the box for about 60 seconds this will wipe the drive and reinstall the tivo operating system
Click to learn more about VIP
Use Kudos to say thanks
Shaznie
Thanks so much for your reply. I did try removing the plug, nothing. Tried so much. Had to call virgin in the end and they replaced the box.. the speed is so much better. Everything became so slow so I’m pleased it happened
