  • 6
Message 1 of 5
Green screen dvr problem
Twice in the last week my virgin box has switched off and has a message saying the DVR has a serious problem with a green background.It may take up to 3 hours to resolve the issue.
  • 353
  • 62
  • 77
Message 2 of 5
Re: Green screen dvr problem
Have you tried replacing the HDMI cable and connect it to a different HDMI port?
If you did then send me a private message, not reply or quick reply, and I'll arrange for a replacement to be sent to you.
Rob
  • 10.76K
  • 842
  • 2.34K
Message 3 of 5
This means the hard drive has died, you'll need a new STB. If you send a text message to this number 07533051809 with all your details inc acc number address problem and someone will get back to you
Message 4 of 5
Hi Robert,
I am having exactly the same problem.
Thanks so much
  • 196
  • 44
  • 92
Message 5 of 5
Hi JM,
Just sent you a PM.
Harry
VM Field Tech
Send Me a PM!
If I've helped in any way, please give me Kudos and mark my response as a Helpful Answer once issue is resolved!
