fatmimi
  • 45
Message 1 of 11
Exclusives and Box Sets
      On my V6 I used to go into On Demand > Box Sets > Channels > Virgin Media Exclusives
Now when I get into that menu under 'Channels' there is no Virgin Media Exclusives? Have they been removed?
Also another quick question Will & Grace is now on demand 8 series of it but its not there when I go into the Sky Comedy folder in On Demand > Box Sets> Channels > Sky Comedy
I have to manually search for it.  Should it be in this folder? Are other titles missing from the folder? It would be easier if they were all listed in there I only found Will & Grace by chance.
japitts
  • 12.07K
  • 1.68K
  • 2.59K
Message 2 of 11
Re: Exclusives and Box Sets
It does look like someone at VM is tinkering with the folder & series ln them, I agree!
Emma_C
  • 8.28K
  • 512
  • 559
Message 3 of 11
Hi Fatmimi,
Sorry there's some issues with the content on our On Demand service.
I also do apologise for the delay in getting back to you, we've been busier than usual.
Are you still finding that this is the case at the moment?
Emma_C - Forum Team
fatmimi
  • 45
Message 4 of 11
Hi Emma yes it is still all the same Exclusives is missing and other content I mentioned only available if you search as its not in the channel folder.
Melissa_F
  • 2.85K
  • 161
  • 230
Moderator
Moderator
Message 5 of 11
Thanks, I've had a check from here and I'm also not able to see that it's in those folders.
I'll make the team aware of this and they can look to have this updated.
Melissa
fatmimi
  • 45
Message 6 of 11
Hi Melissa,
                    Any update on this as there's a lot of shows not shown which we are missing out on unless we search manually.
Another example is PEN15 for Sky Comedy that's also not in the folder.
fatmimi
  • 45
Message 7 of 11
I have also found that Last Man Standing on Comedy Central series 8 is available on demand but that is also not listed in the Comedy Central folder.
There is probably a lot more missing and seems like nothing gets updated.
Ryan_N
  • 2.09K
  • 104
  • 188
Message 8 of 11
Thank you for that - if you could let me know the ones you have come across I can chase this as a collective unit rather than 1 at a time. I appreciate the support.
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
fatmimi
  • 45
Message 9 of 11
Hi Ryan
These are the only ones I have noticed in this thread.
Ryan_N
  • 2.09K
  • 104
  • 188
Message 10 of 11
Thank you 🙂
