  • 3.62K
  • 363
  • 630
Community elder
Message 11 of 13
Re: Dull and Soft Picture Quality
Hi Monikapop, I would be inclined to sorce your own HDMI cable just to satisfy yourself, it won't be the first time virgin have maybe supplied the wrong thing, they don't cost a lot of money.Regards Micky
  • 5.13K
  • 360
  • 886
Superstar
Message 12 of 13
@Monikapop wrote:
Hi Rodger Gooner,
It makes no difference
I think it's worthwhile getting a technician to come round to check the signal strength and do a V6 swap.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 281
  • 13
  • 35
Message 13 of 13
Hi Davidoneman,
Just checked a few things from over here and your signal levels seem to be fine going into your TV box. Can you confirm that the pixelation issue is happening on all boxes in the home? (If you have more than one).
In regards to the WiFi issue, does this affect all devices in the home? Your speeds seem to be fine coming into the property as you say you're getting round the 500mb/s mark near the router. I'd recommend having a quick look at our WiFi Wins forum post to ensure that your wireless set up in the home is good.
Regards,
Beth
