Sree1
Checking Previous Connection To Flats We Plan To Move In.
I am planning to move in to a flat and my daughter is planning to move into the top flat We want to check whether both flats had Virgin Media connection earlier?
Sree1
Re: Checking Previous Connection To Flats We Plan To Move In.
nodrogd
  • 16.48K
  • 1.92K
  • 3.95K
Best thing to do is look inside for the coax connections:
Virgin coax outletVirgin coax outlet
Like the above or similar. VM connections do not normally use flush connection plates & are usually marked with a cable company logo (VM or one of its predecessors). Even if VMs records show the property as being serviced before, if you don't have these connections present you will need a manned install to reinstate them.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
