Ch 5 hd pixelated problems ?
Hi anyone having issues with ch5 hd being very pixelated ?
  • 126
  • 33
  • 34
Re: Ch 5 hd pixelated problems ?
A weak signal, loose connection or a damaged cable are usually the main causes of pixlation.
If you would like to send me a PM i can run a few diagnostics check on your equipment see if it brings anything up.
Craig
Why not try our Text Messaging Service?
It’s a great way to get help with your Virgin Media services - and it's free!
Just send your query to 07533 051 809 and we’ll text you back.
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
I am a serving Field Technician at Virgin however all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
